We currently use the MAX471CSA on a product and I'm looking for an alternative as this IC (MAX471CSA) goes obsolete. Are there any drop in replacements for this IC?
Craig.
LT1787
Production
The LT1787 is a complete micropower precision high side current sense amplifier. The LT1787 monitors bidirectional currents via the voltage across an external...
Datasheet
LT1787 on Analog.com
MAX40204
Recommended for New Designs
The MAX40204 is a high-precision, bidirectional, high-side current-sense amplifier (CSA) with a wide input common-mode range from -0.1V (ground sensing...
Datasheet
MAX40204 on Analog.com
MAX471
Production
The MAX471/MAX472 are complete, bidirectional, high-side current-sense amplifiers for portable PCs, telephones, and other systems where battery/DC power...
Datasheet
MAX471 on Analog.com
MAX44284
Production
The MAX44284 is a high-side, current-sense amplifier that operates with a 1.7V to 5.5V single supply and is optimized for very low power operation with...
Datasheet
MAX44284 on Analog.com
Craig.
GLADION - Moved from Amplifiers to Instrumentation Amplifiers. Post date updated from Thursday, February 22, 2024 3:40 PM UTC to Tuesday, February 27, 2024 7:36 AM UTC to reflect the move.
LiliPod - Moved from Instrumentation Amplifiers to Amplifiers. Post date updated from Tuesday, February 27, 2024 7:36 AM UTC to Tuesday, February 27, 2024 12:43 PM UTC to reflect the move.
GLADION - Moved from Amplifiers to Instrumentation Amplifiers. Post date updated from Tuesday, February 27, 2024 12:43 PM UTC to Thursday, February 29, 2024 2:09 AM UTC to reflect the move.
LiliPod - Moved from Instrumentation Amplifiers to Amplifiers. Post date updated from Thursday, February 29, 2024 2:09 AM UTC to Thursday, February 29, 2024 6:26 AM UTC to reflect the move.
Good day. We are currently looking into this and we'll get back to you.
Gilbeys
Thank you for responding. We are using the device in a system with a 24VDC power rail high side measuring currents of 0 to 1A sent via a 1Mohm resistor to a 5V MPU ADC input. Ideally we'd like a drop in replacement but as this IC uses an integrated current sense resistor I am wondering if this will be possible.
Hi CraigOv ,
Good day. I just had further questions regarding your inquiry. Are you specifically looking for a pin-to-pin compatible device? In your application, are you utilizing the internal Rsense of the part or can we suggest a CSA without an internal Rsense? Thank you.
Gilbeys
Hi Gilbeys, Unfortunately we are using the internal RSense. Yes a pin compatible would be ideal.
Craig.
Hi CraigOv,
The MAX471 uses internal Sense resistor of 35milliohm.
1Mohm is 1mega or 1milli?
MAX471 comes with internal Sense Res, why is sense res used externally?
Regards
Pavaman P
Hi Pavaman, the 1 Mega-ohm is a resistor between the OUT signal from the MAX471 and the input pin of the processor.
To clarify again, we are using the internal Rsense.
Hi Craig, MAX471 is not recommended for New Design and hence would request you to look for parts MAX44284, MAX40204, LT1787. These are few parts with VCM of 36V and suitable for Battery operated applications. These also consume quiescent current in the range of less than 100uA.
I believe that the question has been answered already so I am closing this thread. In case there will be additional questions, feel free to reply to this thread. Thank you!
Paul
