Is this correct Vout is following V-?
VDC=200V
V+=15V
V-=-15V
Vout=-15V
below is EVB with added 49.9kohm resistor at the output.
How shall i configure LT1990 to feed into 4.096V ADC?
LT1990
Recommended for New Designs
The LT1990 is a micropower precision difference amplifier with a very high common mode input voltage range. It has pin selectable gains of 1 or 10. The...
Datasheet
LT1990 on Analog.com
VDC=200V
V+=15V
V-=-15V
Vout=-15V
Hi jiamin: In the first case, the LT1990 output is clipped against the bottom supply as it tries to reproduce -200V. In the 2nd case, the load is too heavy so the output is crushed towards ground. The LT1990 is made for medium small voltages on top of large common modes.
You're trying to compress 200V into 4V, which is a divide by 50. The closest we have is probably the LT1997-2, which will do a divide by 14.5. That would at least get the output within the +/-15V supplies, and then you could further attenuate after that.
Hi
Can further attenuate down to 4.096V?
For V=120V, Vs=+/-15V
