AD8599 voltage range - okay for phonostage replacement
I want to upgrade the old opamp in my phonostage. The voltage 22+/- and would that be okay to use AD8599?
Thank you
Kind Regards
Sam
Parents Reply
    on Sep 11, 2018 6:24 AM in reply to MaccaAu
    Hello Sam,
    One option that you may consider on using is the OP275, please be reminded though that there is no more headroom between the ABSMAX of the device and the voltage voltage on your system, which is not good. If you have an option to lower the voltage in your system then is a good replacement for your part since OP275 suites audio application, and it may also be a plugin replacement to your existing design. It is also a dual channel opamp package in 8 lead PDIP.
    You can also check other high voltage opamp on our website on the link below.
    http://www.analog.com/en/parametricsearch/11088#/p2840=40|140
    Joven
Children
No Data
