OPA LT1359 single power supply using
Dear Sir,
I try to using LT1359 for single power supply application,
got problem for that, any suggestion ?
test1.png is a normal dual power supply
test2.png I try to using single power supply but not work.
Thanks for your time.
Typhoon
attachments.zip
  • Hi Typhoon,
    The transfer function of your circuit is:
    In test1 that you have given the circuit will work just fine since the amplifier will only see it as a non-inverting configuration yielding your correct result.
    In test2 substituting your values on the transfer function your Vout will be 12Vpp at Voffset = -9V which is outside the range of the amplifier with your supply.
    May I know what your intended application is? What is your signal source? Are just trying to center your output? Perhaps you should use a difference amplifier with a dedicated ref pin.
    Best Regards,
    Goz
