No output observed on the Vref1 and Vout1 pin of ADUM3195 , but there is output on Vout2
The user is troubleshooting an ADUM3195 buffer where VOUT1 (pin 6) shows no output and VREF1 (pin 4) is not generating 2.5V. The final answer suggests checking VDD1 (pin 1) for a voltage between 4.5V and 5.5V, ensuring no capacitor is on VREF1, and confirming that pin 7 is tied to GND1. If these checks are correct, the user is advised to share the schematic and measured VDD1.
Product Number: ADUM3195
We were using ADUM3195 as buffer , we are feeding 2.5V into the non inverting terminal (pin 12) .  We observed 2.5V on Vout2 (pin 10) as expected .
Issue : When we were observing Vout1 (pin 6) , there were no output . Additionally we saw that the internal reference generator on the Vout1 side (pin 4) not generating 2.5V as well so I am assuming the demodulator is not getting powered.
Could you help us troubleshoot this ?
This is very urgent as we are in a critical testing phase of our design , prompt help will be greatly appreciated.
Anway
  • Hi
    VOUT2 working only shows that side 2 (the input side) is OK. VREF1 (pin 4) is generated on side 1 from VDD1, and VOUT1 is rebuilt from it. With VREF1 missing, side 1 isn't powered up. Please check:
    1. VDD1 (pin 1) is 4.5 V to 5.5 V, measured against GND1 (pins 2 and 8), not the side-2 ground. Below the 4.2 V lockout threshold, VREF1 and VOUT1 stay off.
    2.There is no capacitor on VREF1. Pin 4 allows 15 pF at most.
    3. Pin 7 is tied to GND1, not left floating.
    If those are all fine, can you share your schematic and the measured VDD1.
    Best Regards,
    Ian
  • Hi , Thanks for the reply , we have used a new IC and powered it on (most likely the previous one had got damaged).
    Now in this initially the IC was working , I was getting both the Vout1 and Vref1 . But while testing , Vout1 stopped working again , this time it was closely following VDD1 (we verified that by lowering VDD1 to 4.5V and at Vout1 we got 4.5V as well) . We are trying to troubleshoot the issue . Could you please tell us what is the cause of such failure mode.
  • Following up on this , we measured impedance between Vout1 and Vdd1 , it was in range of kilo ohoms.
    Anway
