I have a question regarding the power-up sequence for the positive (V+) and negative (V−) supply of the LT6016.
1. Is there a recommended or required power-up sequence between V+ and V−?
2. Could powering up V+ before V−, or V− before V+, potentially damage the device?
3. If either sequence could cause damage, which sequence should be followed to avoid damaging the device?
I was unable to find an explicit specification regarding the power-up sequence between V+ and V− in the datasheet.
Could you please clarify whether the order of powering up V+ and V− matters, and whether either sequence could cause damage to the LT6016?
Thank you for your assistance.
