Hi, can you verify this part for single to differential of CSYNC_IN?
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
AD813
Production
The AD813 is a low power, single supply triple video amplifier. Each of the three current feedback amplifiers has 50 mA of output current, and is optimized...
Datasheet
AD813 on Analog.com
Hi Nita,
The circuit topology looks correct for converting CSYNC_IN to differential outputs. One point to check though is that the recommended feedback for a gain of +1 for +-5v is 750 ohms. Using a lower value may increase bandwidth, but can also result in more high-frequency peaking, overshoot, or ringing.
Please also make sure the CSYNC_IN amplitude and resulting output swing remain within the AD813 operating range.
Best Regards,
Ian
