Replacement needed
Product Number: LT1011AIS8#TRPBF
Sir,
I want a suggestion for a IC similar to LT1011AIS8#TRPBF in terms of functionality, package but temp range should more or equal to -40 degree to +125 degree celcius.
  • Hi
    I could not find a direct pin-compatible replacement in our catalog that has same package that is rated to +125C. Could you please provide the supply voltage, output pull-up voltage/current, required response time, whether the balance/strobe pins are used, and whether PCB modification is acceptable?
    Best Regards,
    Ian
