KCC's Quizzes AQQ306 about a fish stick challenge
1. First the quote of the month: " I am so clever that sometimes I don't understand a single word of what I am saying" - Oscar Wilde
2. New quiz AQQ306 about a fish stick challenge:
Here below is a pseudo fish diagram swimming to the right.
Question
Strong EMC design
AD8479
Recommended for New Designs
The AD8479 is a difference amplifier with a very high input
common-mode voltage range. The AD8479 is a precision device
that allows the user to accurately...
Datasheet
AD8479 on Analog.com
I need some technical support. The thing is working fine, but I want to display the result/output in the oscilloscope, which was not working.
Hi deysarkar,
Since the circuit is working but the result is not appearing on the oscilloscope, please check the measurement setup first. Could you also share the schematic, supply voltage, input signal details, output load, and a photo/screenshot showing where the oscilloscope probe is connected? This will help determine whether the issue is related to probing/grounding, scope settings, or the amplifier operating conditions.
Best Regards,
Ian
I think there is some grounding issue, as when I connect the alligator clip (V⁻) to the common point, the value of the output changes immediately, but using a multimeter in these two points gives correct values. Can it be possible to get the same result in the oscilloscope that I found in the multimeter? I have to record the data for a given frequency.
Hi deysarkar,
If using multimeter gives correct value but oscilloscope does not, it might be due to input impedance in oscilloscope. Typically, you set it between 50 ohm or 1 Mega ohm. Can you check if it's set to 1 Megaohm?
Best Regards,
Ian
