Datasheet is missing details for Long Term Offset Voltage Drift for ADA4522-1. For parts like LTC2055, it is typically mentioned as 50nV / sqrt (month).
LTC2055
Production
The LTC2054/LTC2055 are low power, low noise, single/dual, zero-drift operational amplifiers with an extended temperature version (LTC2054MP) that has...
Datasheet
LTC2055 on Analog.com
ADA4522-1
Recommended for New Designs
The ADA4522-1 / ADA4522-2 / ADA4522-4 are single/dual/quad
channel, zero drift op amps with low noise and power, ground
sensing inputs, and rail-to-rail...
Datasheet
ADA4522-1 on Analog.com
Hi Krn,
Long term offset drift isn't typically part of standard production testing since it requires extended aging to measure. May I ask why you need this data?
Ian
Hello Ian,
I am planning to use this on a highly accurate electrical instrument & interested to know what is the offset drift does the IC undergoes in 1 year. I notice that for productions parts like LTC2055, it is typically mentioned as 50nV / sqrt (month).
Hello Ian, I am planning to use this on a highly accurate electrical instrument & interested to know what is the offset drift does the IC undergoes in 1 year. I notice that for productions parts like LTC2055, it is typically mentioned as 50nV / sqrt (month). Please can you comment long term drift of ADA4522-1.
Hi Krn,
LTC2055 specifies long-term drift because its auto-zero architecture relies on periodic sampling and storage of the offset correction, which can introduce a very small statistical random-walk component over long periods. Similar long-term offset change can also be observed in older laser-trimmed architectures, which do not have dynamic offset correction and are therefore subject to device aging.
For chopper-stabilized op amps such as ADA4522, long term offset drift is not specified because the continuous chopping mechanism dynamically removes offset, including any offset introduced by aging, making long-term drift a non-meaningful error term for this architecture.
You may refer to this article for additional information:
MT-037: Op Amp Input Offset Voltage
Best Regards,
Ian
Hello Ian,
Thanks for your reply. For the chopper-stabilized opamps, I understood that auto-zero circuit removes any offset due to aging. Does the auto-zero circuit also removes the voltage offset & voltage offset's temp drift?
