Hi everyone,
I'm encountering an issue with the AD8599 when used as an integrator (see schematics below).
All AD8599 op-amps in the circuit are powered with +15V and -12V.
The problem: when the output of the adder is positive, e.g. at TP14 is 70mV, the integrator output (TP17) should, in theory, gradually move towards a negative voltage. However, this doesn’t happen and the output remains stuck at +14.2V.
The integrator output voltage slowly decreases to -2V when the adder output (TP14) reach 0.8V. At 0.9V at TP14, the op-amp integrator output reach is minimum of -10.8V.
After the integrator, there's another voltage follower (identical to the one before the adder). I understand that the AD8599 isn’t rail-to-rail, so having an integrator output that swings from +14V to -11V it's not ideal when another AD8599 stage following it. However, this is the only place in my circuit where this issue occurs, so I added 10k resistors on both the inverting and non-inverting inputs of the voltage follower also to limit the current through the ESD diodes to less than 5mA, as suggested in the datasheet. Also the ABS MAX for the input voltages of the AD8599 says that −Vs ≤ V IN ≤ +Vs. So, again, it's not ideal, but it should work.
Both the voltage follower and adder works fine, but I expect the integrator to produce a negative voltage when a small positive voltage is applied at the input—even with just a few hundred millivolts.
Am I missing something?
Thanks for your help!
