LTC6258 is end of life, I read. We use it for a mid-rail because it's stable behaviour with high capacitive load, small outline and low voltage/low power. Could someone advice on a replacement? Thanks a lot
KCC's Quizzes AQQ304 - A pure logic
1. Quote of the month: "I am not lazy, I'm just in energy-saving mode" - unknown
2. Quiz AQQ304 about finding a pure logic puzzle
Mike is looking at Anne, but Anne is looking at Paul.
Mike is married, but Paul is not.
Question:
Is a married
August Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Important: Read the blog first . The quiz questions are all based on the content of the blog:
Stay in the loop and win! Read the blog Current Output Driving Industrial Loops , then take our quick five-question quiz for a chance to win a gift card
LTC6258
Last Time Buy
The LTC6258/LTC6259/LTC6260 are single/dual/quad operational amplifiers with low noise, low power, low supply voltage, and rail-to-rail inputs and outputs...
Datasheet
LTC6258 on Analog.com
Hello Fedde ,
Thanks for reaching out. Could we know how large your capacitive load is on your application? That would help us pick a replacement op amp.
Also, may we know what maximum voltage/power would you accept? and is the shutdown pin necessary on your application?
Best Regards,
Kenneth
Thank you for your swift response, Kenneth.
My application has a 3V power rail, mid rail is 1.25V. Less than 5mA will be used on this mid rail. Shutdown is not necessary. I use a 10uF and 100nF (both mlcc) to decouple the mid rail. (Probably 1uF should also be enough.)
Thanks for the information Fedde. Do you have schematic that you can share? Planning to compare results on LT spice simulation once I found a good replacement.
Best Regards,
Kenneth
Here's part of the schematic, most of the circuit works with an AM modulated 8kHz sine wave.
