Im trying to open spice file for the DC2622A which utilizes two ADA4899-1 as a single ended to differential converter aswell as driver for an ADC. I get this message when i try to open the spice file
ADA4899-1
Production
The ADA4899-1 is an ultralow noise (1 nV/√Hz) and distortion (<−117 dBc @1 MHz) unity-gain stable voltage feedback op amp, the combination of which...
Datasheet
ADA4899-1 on Analog.com
Hello Abdelhakim,
Upon checking, it seems that the .asc file on DC2622A's design files is not an LTSpice file but a PCB file. I'm not quite sure why it is in the .asc format.
To be able to simulate how DC2622A's evaluation board works, you'll have to manually create its schematic on LTSpice using the demo board schematic file on DC2622A Evaluation Board | Analog Devices as a reference.
Paul
