Dear Sir:
I recently purchased the ADA4899-1 op amp. I have provided a link to the data sheet for your convenience.
If you look on the data sheet at the "package" type diagrams you will see this note that says:
"THE EXPOSEDPAD MUST BE SOLDEREDTO THE GROUND PLANE"
Underneath the AD4899-1 IC is a metallic pad for those who do not own the IC.
I have read in other literature that this ground connection is called a "ground paddle" (please correct me if I am mistaken).
I need to know how to connect this "ground paddle" point in both single and dual power supply operation. If you can lease provide a schematic for the single power supply configuration.
Further, this ground point adds complexity to the typical SOIC 8 "footprint". I need to download the "footprint" of this part and import it into my layout program.
Is there a generic footprint filename extension common to all, or most, layout programs, that I can download from ADI?
