-55C rated zero drift Opamps
Can you please suggest -55C rated zero drift Opamps. Much appreciate if you can suggest miniature packages
Parents
  • Hi ,
    Good day. You may want to look at AD8629 which is a Zero-Drift, Single-Supply, Rail-to-Rail Input/Output Operational Amplifier with a rated temperature range of -55C to 125C available on 8-pin MSOP and SOIC_N package. Also, you may also want to look at ADA4528-2-EP which is a Precision, Ultralow Noise, RRIO, Zero-Drift Dual Op Amp with a temperature range of -55C to 125C available on 8-pin MSOP and 8-lead LFCSP. Feel free to ask if you have other parameters in mind to consider in your selection. Thank you.
    Gilbeys
Reply
  • Hi ,
    Gilbeys
Children
