Questions about LT6011
Category: Datasheet/Specs
Product Number: LT6011IS8
I am operating LT6011 with supply voltage V+=1.8V, V-=-1.8V. Due to a situation on the power supply side, V+=1.8V is cut off (V+=OPEN) during standby.
Also, there is no input at standby. At standby: V+=OPEN, V-=-1.8V, Input: +IN=-IN=0V
Is there any problem with this kind of usage (V+=OPEN)?
Kazu
Top Replies
  • Hello  ,
    Just a few clarifications, what do you mean by V+=OPEN? Does it mean the V+ supply pin is not connected to anything? or the V+ supply is connected to a voltage supply with no voltage configured (Ex. 0V/GND)?
    In addition, during standby, are the op amp's inputs floating (don't have connections)?
    Paul
  • Hi Paul,
    The standby state is as follows.
    The V+ pin is not connected to anywhere. The V+=1.8V line is turned off by a MOSFET switch.
    The op amp's inputs are 0V, not floating.
    Kazu
    This may not damage the opamp as long as correct power sequencing is followed:
    • During the Power On sequence, turn on the supply first, then apply a signal at the input
    • During the Power Off, turn off the input signal first, then turn off the power supply
    One problem that I can see from this is that the opamp will not work as it intended to be during standby. The negative voltage from V- pin can pass through the V+ and Output pin. See simulation below:
    V(n001) = V+ Supply Voltage
    V(n002) = Output Voltage
    If the V+ pin and Output pin are connected to terminals of other chips that haven't been fully powered, those chips may suffer damage.
    For more information regarding this topic, please see: Improper Power Sequencing in Op Amps: Analyzing the Risks | Analog Devices
    I hope this helps. Thanks.
    Paul
  • Hi  ,
    In addition to what   said, I think it is not a good idea to use the opamp out of what is specified even is the maximum ratings seem to be met. Do not let the supply pin V+ float. Although I don't know why do you want to switch off the positive supply, find another solution that fits to your needs.
    And yes, be careful with power supply sequencing.
    Zoltan
