Alternative of LT1351
Product Number: LT1351
On my previous design, I used LT1351 opamp not it is not availlable in the market. Do you recommend any other opamp with same features?
Thank you,
  • Hi AE104:  that family has the same footprint in part number increments of 3.  So for example LT1354 should work, also LT1357.  The bandwidths and slew rates rise, so you'd want to double check stability.
    Also, the LT1351 had a shutdown pin, which the others do not.
    If your application is not using the high sew rate of the opamp, then there may be more alternatives.
