LT1028 Phase Margin
Category: Datasheet/Specs
Product Number: LT1028
Software Version: LTSpice XVII 17.0.35.0
I'm simulating the open loop gain/phase for an LT1028 and my result differs from the datasheet at Av=1.  I get a phase margin of almost 45 degrees and as it is not unity gain stable  it should be closer to 0 degrees per the figure on page 8 of the datasheet.  I have used 2 different methods of obtaining the OL gain and the results are the same.
Can you shed any light on why I have a larger phase margin in the simulation than I should expect given datasheet specs?
  • Hi Tim,
    Thank you for your feedback.
    It may be a case of modelling trade-off.
    The phase plot is not the usual shape for op-amps, and it seems that the modeler gave priority to getting the shape of the phase closer to the datasheet.
    We will forward your feedback to the developers.
    Thank you,
    Sham
