In ADA4870 datasheet, it mentioned this part could be ideal for driving high capacitive load; could you please share some idea why ADA4870 could drive high capacitive load comparing with other normal voltage feedback amplifier?
Thanks
ADA4870
Recommended for New Designs
The ADA4870 is a unity gain stable, high speed current feedback amplifier capable of delivering 1 A of output current and 2500 V/μs slew rate from a 40...
Datasheet
ADA4870 on Analog.com
Thanks
Current feedback op amps traditionally have wider bandwidths and higher slew rates than voltage feedback amplifiers. It is ideal for demanding applications that require high speed from high supply voltage at high output current. Do you have any application in mind? What type of signal are you looking to drive into what levels of capacitive load?
Kay
