LT1782 short circuit protection
Product Number: LT1782
I am evaluating if the LT1782 has short circuit protection or not.
Looking at the circuit diagram from its datasheet, it seems to me that the output stage HAS NOT a short circuit protection circuit.
Also, the datasheet does not mention nothing about it.
Could you confirm ?
Simon
    It is a simplified schematic, so does not contain all of the components. The datasheet specifies the short-circuit current, so the part limits the output current. Don't forget to read the related note about heat dissipation. In the absolute maximum ratings table you can also see a statement: 'Output Short-Circuit Duration: Indefinite'. However, the heat dissipation should be kept within the specifications, as note 2 says ('A heat sink may be required to keep the junction temperature
    below absolute maximum.').
