Hi
For LTC6262 op-amp the Shutdown threshold is 0.6V above the negative rail. (Active Low Shutdown )
Usually, the op-amp shut down logic is given by MCUs.(TTL or CMOS)
But when using both negative and positive voltage rail, there is no way to shut down the op-amp with TTL or CMOS logic level Voltage. (without external components)
maybe it is possible to shutdown the op-amp if the Shutdown pin is active High,(maybe I am wrong)
why that is not considered in the IC design?
is that not possible in IC?
Please Let me know why?
Thank you
