Hi Adi
I use a AD8675 in a circuit just before a DAC. It buffers a voltage reference signal of 5V.
Recently the op amp did not work after a start up. +-15V was applied as supply voltages.
I wonder if start up sequence not was not correct. Maybe 5V on op amp input was applied few uSec before supply voltages were up at AD8675.
How sensitive is the op amp for these situations? Will they typically die? Inserting a resistor to limit current to 10mA is not very convient to or good for the noise performance in actual circuit.
cheers
