ADA4896 micro spice model for LTSPICE use
Hi
The ADA4896.CIR doesn't work for LTSPICE. The BF value is a big negative value.
Could you post an alternative spice model working for LTSPICE? Any format is ok.
by the way, the AD8067 model doesn't converge in MultiSim. I have to use it in LTSPICE.
LJ
ADA4896.cir.zip
  • Use this model but you will have issues with the way LTspice interprets our noise generation method.
    *************** +IN -IN Vcc Vee Out
    .subckt ADA4897 1 2 99 50 4
    ***Differential Stage
    Q1 13 12 14 npn
    Q2 17 2 16 npn
    Rc1 98 13 Rideal 3.400E+00
    Rc2 98 17 Rideal 3.400E+00
    Re1 14 15 Rideal 3.348E+00
    Re2 15 16 Rideal 3.348E+00
    Ibias 15 51 1.00E+00
    Dcmlim1 18 15 DQUIET
    Vcmlim1 18 51 0.526
    ***Voltage Noise Generation
    HVnoise 9 7 Vvnoise 1
    VVnoise 501 0 0
    DVnoise 501 0 Dvnoise
    RVnoise 501 0 0.01656
    ***Current Noise Generation on +IN
    FInoise1 12 0 VInoise1 1
    VInoise1 502 0 0
    DInoise1 502 0 DInoise1
    RInoise1 502 0 204.4444444
    ***Current Noise Generation on -IN
    FInoise2 2 0 VInoise2 1
    VInoise2 503 0 0
    DInoise2 503 0 DInoise2
    RInoise2 503 0 204.4444444
    ***Common Mode Injection
    Rcm1 1 601 Rideal 100Meg
    Rcm2 2 601 Rideal 100Meg
    Gcmr 0 602 601 75 1.00E-06
    Rcmr1 602 603 Rideal 1Meg
    Rcmr2 603 604 Rideal 1.585E+01
    Lcmr 604 0 3.604E-05
    Ecmr 10 9 603 0 1.000E+00
    ***Positive Power Supply Rejection
    Epsr1 700 0 98 0 1
    Rpsr1 700 701 Rideal 1.00E+02
    Rpsr2 701 702 Rideal 7.080E-03
    Lpsr1 702 0 1.878E-08
    Epsr2 11 10 701 0 1
    ***Negative Power Supply Rejection
    Epsr3 703 0 51 0 1
    Rpsr3 703 704 Rideal 1.00E+02
    Rpsr4 704 705 Rideal 3.981E-03
    Lpsr2 705 0 1.267E-08
    Epsr4 12 11 704 0 1
    ***Input Offset and Bias
    Vos 1 7 5.000E-04
    Ios 1 2 5.000E-08
    ***Input Impedance
    Cinv 2 0 1.00E-12
    Cninv 1 0 1.00E-12
    ***1st Gain and Slew limiting
    Gslew 0 101 17 13 1.0000E+00
    Rslew 101 0 Rideal 2.50E+02
    Dslew1 101 102 DZENER
    Dslew2 0 102 DZENER
    ***Second Gain and Dominant Pole with Output Voltage Limiting
    Gp1 51 201 101 0 6.032E-06
    Rp1 201 51 Rideal 6.631E+07
    Cp1 201 51 1.50E-12
    Vlim1 97 206 0.75
    Dlim1 201 206 dquiet
    Vlim2 207 52 0.75
    Dlim2 207 201 dquiet
    Esupref1 97 98 51 0 1
    Esupref2 52 51 51 0 1
    ***Second Pole
    Gp2 0 202 201 51 1.00E-03
    Rp2 202 0 Rideal 1.00E+03
    Cp2 202 0 9.94719E-13
    ***Third Pole
    Gp3 0 203 202 0 1.00E-03
    Rp3 203 0 Rideal 1.00E+03
    Cp3 203 0 1.59155E-16
    ***Fourth Pole
    Gp4 0 204 203 0 1.00E-03
    Rp4 204 0 Rideal 1.00E+03
    Cp4 204 0 1.59155E-16
    ***Fifth Pole
    Gp5 0 205 204 0 1.00E-03
    Rp5 205 0 Rideal 1.00E+03
    Cp5 205 0 1.592E-16
    ***First Zero
    Gz1 0 301 205 0 1.00E-03
    Rz1 301 302 Rideal 1.00E+03
    Lz1 302 0 1.592E-10
    ***Second Zero
    Gz2 0 303 301 0 1.00E-03
    Rz2 303 304 Rideal 1.00E+03
    Lz2 304 0 1.592E-10
    ***Third Zero
    Gz3 0 305 303 0 1.00E-03
    Rz3 305 306 Rideal 1.00E+03
    Lz3 306 0 1.59E-10
    ***Buffer
    Gbuf 0 401 305 0 1.00E-04
    Rbuf 401 0 Rideal 1.00E+04
    ***Output with current limiting
    Eout 404 0 401 0 1.000E+00
    Rout 404 405 RIDEAL 1.000E+00
    Lout 405 406 1.00E-19
    Cout 406 0 1.00E-22
    Voutmon 406 4 0
    Dout1 401 407 Dquiet
    Vout1 407 406 -5.600E-01
    Dout2 408 401 Dquiet
    Vout2 406 408 -5.600E-01
    ***Voltage reference generator
    Eref1 98 0 99 0 1
    Eref2 51 0 50 0 1
    Rref1 98 901 Rideal 100Meg
    Rref2 901 51 Rideal 100Meg
    Eref3 75 0 901 0 1
    ***Supply current correction
    Iq 99 50 0.0015
    Fsup1 99 0 Voutmon 1
    *DZsup1 0 802 DZENER2
    *Dsup1 99 802 DQUIET
    Fsup2 0 50 Voutmon -1
    *DZsup2 804 0 DZENER2
    *Dsup2 804 50 DQUIET
    ***models
    .model Rideal res T_ABS=-273
    .model Rnoise res T_ABS=27
    .model npn npn BF= 49999
    .model dquiet d
    .model dvnoise d KF=3000
    .model dinoise1 d KF=0.81
    .model dinoise2 d KF=0.81
    .model dzener d BV=24.2679808631935
    .model dzener2 d BV=50
    .ends
  • Hi.
    Is there any workaround to simulate noise in LTSpice? Looks like the issue is the generation of flickr noises using the diode model...
    Thank in advance.
