Queries about AD8099
Dear Supporter,
I have a query about AD8099. I use AD8099 in my product. The package is SOIC-8.
The power supply is +/-5V. The gain is set as -10.
Input signal is square wave with the frequency of 2MHz.
After increasing the input amplitude, the output gets its full range.
The output has over-shoot. My schematic and testing results are attached for your reference.
I tested with signal generator and oscilloscope, which means the output doesn’t have capacitive load. We used AD817 and AD847 before, AD817 and AD847 worked well.
I have two queries here.
1, why is there over-shoot here? How can I eliminate it?
2, I read the description of Pin Cc in the datasheet. It is used as compensation for the gain range of –1, +2 to +10. Is it worked for the gain of -10? Is it the over-shoot caused by the poor compensation work design?
Could you please help give some comments on the issues?
Thanks in advance for your help and support!
Br,
Wayne
attachments.zip
  • Wayne,
      -- A scope probe or the input of a scope still has a few pF or more of capacitance.
    --  If the AD817 and AD847 worked, why would you use a part that is 10x faster,
      10x the supply current and much harder to work with?
    --  Over shoot indicates low phase margin.
    --  Are you using a pc board w/ at least four layers?
    --  Do you have two bypass caps on each supply VERY close to the package?
    --  Did you cut away all traces on all layers below the inverting input?
           If you have 1 pF of C on that node, your noise gain will increase with increasing frequency,
      leading to instability.
    --  Did you try making C15 1.1-4.7 pF??
    Harry
  • hello, Harry
    I think I've got your points here and will try with your suggestion. Any update or result will keep you informed.
    Thanks!
    Br,
    Wayne
    on Aug 2, 2018 2:48 PM
    Thank you,
    EZ Admin
