Voltage follower on ADA4692 cut of the signal
I try to create simple voltage follower on ADA4692 but there was a surprise. In some reason it cut of the signal. In any follower shemes. I try all possible shemes. If I tied input to Vcc (3V) the output is still on cutt-of position (near 2V). Any other opAmp working properly.
So can someone tell me how to build voltage follower with this opAmp?
On img you can see  the result of simulation using LTspice
Thnk you for answers)
Parents Reply Children
No Data
