can OP07 be used with single supply ??
HI Everyone,
Can  I use op-amp IC OP07 using single supply voltage of +5 Volt?. While doing so which characteristics I am going to loose?
Thanks and Regards,
rahul
  • Yes, but not with 5V;  you need at least 6V across the part.
    But why choose  an OP07 that is over 30 years old?  We have done many generations in the OP07 family,
    OP07 -> OP77 -> OP177 -> OP777 -> OP1177 -> AD8671/8675 -> ADA4077-1.
    The ADA4077-1 does run on 5V, but if you want low offset, look at the chopper type amps, such
    as AD8638 or ADA4522-1.
    Harry
