maximum output current of "OP200A "
please, maximum output current of "OP200A"
 It used "Derating Analysis Document" of satellite system part
    Let us check for this data. We'll get back to you once it's available.
    Goz
    We typically recommend to design to an output current of +/-10mA for your application. The circuits in the Applications section of the datasheet are designed around this number.
    May I ask how the OP200 will be used in your specific application?
    Kris
  • HI
    Thank you for your reply.
    The output current used in real application(satellite system) is very small
    However, to write a derating document(part analysis document), Need the output current value of the part.
    Is it possible to define the value of +/-10mA as the maximum current value of op200?
    Thank you
    Daejin, Kang
      <http://www.satreci.com/> www.satreci.com
    Research Engineer. Kang, Daejin
    Electronics Engineering
    Space Team 2, Space Technology Research Institute
    21 Yuseong-daero 1628 beon-gil,
    Yuseong-gu, Daejeon 34054, Korea
    Tel : +82 42. 602. 7344
    Fax : +82 42. 365. 7559
    Mobile : +82 10. 9283. 1654
    Email : kangdj@satreci.com
    Arrow forward 본메일에는 비밀정보가 포함되어 있을 수 있으니 업무목적외 부정사용 및 사전 승낙없이 공개, 누설,
    제공을 금지하여 주시기 바랍니다.
    Arrow forward This e-mail is for use by the intended recipient and contains information that may be privileged,
    confidential or copyrighted under applicable law. If you are not the intended recipient, you are hereby
    formally notified that any use, copying or distribution of this e-mail, in whole or in part, is strictly
    prohibited. Please notify the sender by return e-mail and delete this e-mail from your system. Unless
    explicitly and conspicuously designated as a formal contract, this e-mail does not constitute a contract
    offer, a contract amendment, or an acceptance of a contract offer. Please check this e-mail for virus
    infection, for which Satrec Initiative Co. Ltd. cannot accept any responsibility.
  • Hello,
    I tried to check back to see if we could find any data for the maximum output current of this device. Unfortunately, because this part is quite old, that data does not exist.
    The +/-10mA spec is only a typical spec (25C) and would not have been fully characterized.
    Apologies if I cannot be of more help.
    Kris
  • HI
    Can you send me the data of OP400A(maximum output current)?
    I am asking, because I think the characteristics of OP200A and OP400A are the same.
    If, you have not data of OP400A, Do you have any available reference material to help me ?
    Thank you very much for your kind answers.
    Daejin, Kang
  • It's funny, I have the same question. I ran a simulation and it cuts out about at 20mA.
    I can't tell though if it's inherent in the model or not.
  • Figure 25 of the datasheet has short the circuit current graph at 25C.
    That should close the discussion.
