AD7667 input question
hi all:
      Looking at the AD7667 datasheet, I have troubles understanding Figure 45. Using the AD7667 in 16-Bit Bipolar and/or Wider Input Ranges.
Why the op amp can convert  ±10V to 0-2.5V. Should U2 connect the analog input signal to R2 and R3? But the gain is not right.
thanks
Parents Reply
    In fact, to input connect the reference voltage, not R3. U2 provide calibration or autozero mode. In datasheet says about this: "When desired, accurate gain and offset can be calibrated by acquiring a ground and voltage reference using an analog multiplexer (U2), as shown in Figure 45".
    Kirill
Children
No Data
