as shown as the picture above, I connect the vin+ with vin- and power is ±5V, gain is 80. But the noise is about 10mV from oscilloscope.How can I reduce the noise?
Thanks!
Strong EMC design
AD8421
Recommended for New Designs
The AD8421 is a low cost, low power, extremely low noise, ultralow bias current, high speed instrumentation amplifier that is ideally suited for a broad...
Datasheet
AD8421 on Analog.com
ADR435
Production
The ADR430/ADR431/ADR433/ADR434/ADR435 series is a family of XFET® voltage references featuring low noise, high accuracy, and low temperature drift performance...
Datasheet
ADR435 on Analog.com
Thanks!
Moved from Instrumentation Amplifiers to Amplifiers on Thursday, November 23, 2023 11:43:03 AM by DPFATE_DP
Moved from Amplifiers to Instrumentation Amplifiers on Thursday, November 23, 2023 11:42:25 PM by GLADION
Output is just like the picture above. but it is the result of gain = 4000. No input signal. I connect the vin+ with vin- and you can refer to the circuit of my question.
Thanks!
Hi DPFATE_DP,
Could you check the noise on your power supply as well as your vref?
Franz
Hi Franz,
I am so sorry. My previous description is wrong. In fact, I use two AD8421 to get two stage of amplifier. the Gain of first stage is 80 and second stage is 50. The test circuit of first stage is shown as the picture in my question and its output is connected with the VIN+ of the second stage. And the VIN- of the second stage is connected with GND. I found that approximately 10mv noise is generated on the power supply pin.
Hi DPFATE_DP,
Since there is also a 10mV noise on your power supply pin, the noise may come from your power ICs. You may check your power management for noise sources. AD8421 needs a stable DC voltage as the noise can adversely affect performance.
You may place a 0.1uf decoupling capacitor as close as possible to each supply pin.
I hope this helps.
Franz
Hi Franz,
Could you give me some advice about which power ICs I should select ?
Hi DPFATE_DP,
You may want to consider ADR435 which has a very low-noise output. However, please consider that ADR435 is a voltage reference IC with only 30mA of output current. This might not be sufficient if you will use this for your other ICs.
Kindly visit our power management forum to inquire about a proper power management IC for your system.
I hope this helps.
Franz
