The data sheet only mentions Internal Op Amp Gain Bandwidth 200kHz.
Is there any information on the bandwidth for each gain?
Should I simply consider the GBP product constant?
LTC6915
Production
The LTC6915 is a precision programmable gain instrumentation amplifier. The gain can be programmed to 0, 1, 2, 4, 8, 16, 32, 64, 128, 256, 512, 1024, 2048...
Datasheet
LTC6915 on Analog.com
Hi Uboti,
Unfortunately we don't have any other internal file that shows BW performance for each gain set for LTC6915. Additionally, not all in-amps can use the GBP method since they are not designed similarly to an op-amp. Let me reach out to our designers and confirm any data we have for LTC6915 and get back to you.
Thanks and regards,
Kristine
Hi UBOTI if there are no other inquiries on your end. We will close this thread. If there will be a new question from your end you can submit a related questions for this thread and for it to be reopen.
