I have tried several times for genarate a Gain in ADA4254 and also tried it's self test mode by setting the TEXT_MUX register and provided the input signal . But i can't find a siginal output on it ,can you please recommend a solution for this
ADA4254
Recommended for New Designs
The ADA4254 is a zero drift, high voltage, low power programmable gain instrumentation amplifier (PGIA) designed for process control and industrial applications...
Datasheet
ADA4254 on Analog.com
Hi Abhinav098,
Could you please attach a schematic or simulation of your design where ADA4254 is included? This would help us identify the problem and provide a solution for you.
Thanks and regards,
Kristine
Hi Abhinav098
Please let us know if you can provide these details being requested on your end. For the team to understand your inquiry further and be able recommend the suitable answers.
