LTC2053 Differential Input Questions
Hello
The differential input voltage range is listed on page 10 of the LTC2053 data sheet.
Please tell me about the operation when a differential input outside this range is given.
Does it stick to the power supply voltage?
Or will it be indefinite?
I would appreciate it if you could reply.
Best regards
Knj
    on Jul 15, 2021 3:59 AM
    Hi knj,
    Good day!
    Normally if the device is used outside the operating range given in the datasheet, the output will be indeterminate as it's already operating in nonlinear region.
    We'll be able to help out further if you can give us your specific application.
    Figure 1 shows more details with regards to the operating range of LTC2053 at different configurations:
    Hope this helps.
    Best Regards,
    Dann
