The EVAL ADA4558 has a calculator app with coefficients, which can be defined before calling the app depending on the target linearity and needed factors.
The file is set to standard parameters and cant modify it as admin.
I can modify the file as text file, save it, but the changed parameters are not took in account and the app works only with the standard values.
I cant found in the datasheet something where this values are stored or how to modify them.
Ill be thankfull for further help.
