Supply voltage for AD8557 programming
On your datasheet it is indicated "A 5.75 V (±0.25 V) supply is required when blowing fuses to minimize the on resistance of the internal MOS switches that blow the fuse"
On your evaluation board (AD8556-EVALZ/AD8556CP-EBZ) the supply voltage is 5V but it allows the programming of amplifiers.
Should I generate 5.75V voltages to burn the fuse or a 5V power is sufficient?
