Can ADA4817 be supplied by +6.5V /-3.5V rail for a long time
Dear Sir or Madam
As I say at the Subject Column , can ADA4817 be supplied by +6.5V /-3.5V  rail  running forever ? while the load of the amplifier is about 130ohm , the input signal is between -2V to +5V .
In addition , I am debugging a board relevant to ADA4817-2 . recently I found it didn't work well , there was always about 6V at Pin5 . Having replaced it with a new chip , it could work well again .
So could you mind please give me some tips to figure it out .
Thank you.
Anglic
    on Sep 5, 2019 8:52 AM over 1 year ago
    Hello Anglic,
    Apology for the late response.
    -Yes, you may run this product using this supply as it is still within the required supply stated at the data sheet, 10v.
    -The IVR ranges from -Vs to (+Vs – 2.8V). Thus, the input signal that can be processed will be only at -Vs to +3.7V.
    In addition, please take I look on AD8000. It may suit to your requirements plus it has higher current load drive as compared to ADA4817.
    In addition , I am debugging a board relevant to ADA4817-2 . recently I found it didn't work well , there was always about 6V at Pin5 . Having replaced it with a new chip , it could work well again.
    -It would be helpful if you can share to us the schematic of the circuit you are working of particularly on the use of this product.
    Hope this may help.
    Fdelaram
  • Hey Fedlaram
    Thank you very much .
    Would you mind to post the IVR parameters here from the datasheet with a picture , For I didn't find it as you mentioned .
    And , I guess the former ADA4817 was damaged by the heat . Would you  mind that help to calculate the maximum total  power  of each amplifier .
    I'll really appreciate for your help
    Best regards.
    Anglic
    on Sep 17, 2019 8:48 AM over 1 year ago in reply to angelic
    Hi Anglic,
    The IVR parameter can be found on page 5 of the data sheet.
    Also, you can use this formula for computing the Power Dissipation(PD).
    Fdelaram
