AD8555 Read mode not working
I am checking a new design with AD8555. I have not connect the Strain Gauge sensor yet but i want to verify chip is working. I am trying to go into Read mode and check that chip replies back.
I am sending the 1000 0000 0001 11 00 10 0000 0000 0111 1111 1110 code to read the second stage gain but there's no output on the DIGOUT pin.
  • Bit '1' =  85 usec
  • Bit '1' =  6 usec
  • Time between pulses = 22 usec
As you can see in the picture, the DIGOUT pin stays low. Is there something i misunderstand?
    I'll contact the product owner of this part to address your concern.
    Thanks.
    Have you programmed the AD8555 prior to entering the read mode?
    According to the datasheet, in Read Mode the output of the FILT /DIGOUT pin corresponds to the polysilicon fuses programmed prior to entering Read Mode. If you try to read before programming, it is possible that due to the fuses' default value nothing gets shifted out on the FILT/DIGOUT pin, maybe this is what you are seeing. This is the way I interpret it, I will double check with the designer and update you if there is a change of scheme that I'm not aware of.
    Sarah
