Portable ECG design with the AD8233.
Hi.
I am currently working with the AD8233 chip for the acquisition of ECG signals, I have previously used the AD8232. In order to improve the product and decrease the size of the PCB, I have chosen to use the AD8233. The problem I have is the following: The pitch between the balls of the AD8233 is 0.4mm, this means that there can be no tracks between its pins, therefore I must use vias in pad.
I plan to use vias whose diameter is 8 mil. Now my PCB is 4 layers, my question is if I can use these vias in pad from the top layer to the bottom layer?
I am not very clear if this can be done, I have read a lot of the subject, but some recommend using blind vias that go from the top layer to the closest plane.
I would appreciate if you can give me information on how to solve this problem with the layout of the AD8233.
Parents
  • Thanks
    Very useful your appreciation. I had reviewed both materials, but I could not understand clearly, reviewing the documentation of other manufacturers I could understand more clearly.
    In my case the AD8233 is in the Bottom layer place the microvias up to the vcc plane (layer 3), I use track of the 3 mils of width. And guiding me by the photos of the evaluation board I make the route of the signals.
Reply
  • Thanks
Children
No Data
