How to interface for single ended output
Product Number: AD8332
I am using Ad8332 in my circuit and want to feed VGA out to a LOW PASS FILTER that has single ended input.
What should be the circuit connections to use VGA for single ended output
Top Replies
    •  Super User
    in reply to maaarmas +1 verified
    Hello  ,
    Thank you for patiently waiting. You can use the provided Differential-to-single-ended transformers in the evaluation board for single-ended output connections or you can also use a differential…
Parents Reply
  • Hello  ,
    Thank you for patiently waiting. You can use the provided Differential-to-single-ended transformers in the evaluation board for single-ended output connections or you can also use a differential-to-single-ended amplifiers. After this you can add the lowpass filter circuit.
    You may want to simulate the circuit using the LTspice by downloading the web model of the AD8332 that can be seen in the product page.
    I hope this information helps. If you have further questions, please feel free to ask.
    Mae
Children
No Data
