Hello everyone...
Does anybody know what is recommended power supply range for AD8210? Can it be powered by 3.3V? In the device datasheet it is only mentioned that The typical supply voltage is 5 V.
Thanks in advance!
Hello everyone...
Thanks in advance!
Hi Miodrag,
It is as ZoltanDTI specified; based on the datasheet, the supply range is only between 4.5V to 5.5V.
For an alternative part, you may try exploring selections via parametric search.
-jean
The LT6105 says it will work down to 2.85V and may work for you.
