running a voltage noise simulation in LTspice with a simple voltage follower circuit shows a large discrepancy to datasheet values for the voltage noise.
To make sure nothing was wrong with my simulation I also checked the LTC6226. Below is a comparison from simulation output vs. datasheet curves. The LTC6226 on the right is a pretty close match betwen spice model and datasheet, the LTC6228 on the left is completely off.
For example at 10Hz:
- LTC6228: datasheet:~20nV/SqHz vs. simulation: 60nV/SqHz
- LTC6226: datasheet:~18nV/SqHz vs. simulation: 18nV/SqHz
So for the LTC6228, is the datasheet correct or is the spice model correct?
added example values at 10Hz
[edited by: DamianS at 12:57 PM (GMT -4) on 30 Jul 2021]
