Are there any information available for ADA4841-1 about the voltage noise density vs. frequency in the range 0.1Hz to 10Hz?
If not, are there information available about the 0.1Hz to 10Hz voltage noise (peak-peak)?
I will use the ADA4841-1 as a reference buffer for the ADR444 and the ADR444 has noise from 0.1Hz to 10Hz listed in its specifications.
I am a little concerned about low frequency noise and would like to check the noise data from 0.1Hz to 10Hz for ADA4841-1.
Kazu
