Just double checking if its ok for me to power the LT1638 using 24V single power supply?
Sometimes this voltage may go up to 35V, is this still within spec?
Dan
Dan
Hello Luc123,
for a spec related questions a look in the spec is often very helpful:
In the datasheet of the LT1638 we state on page 1 following:
This should answer your question, correct?
kind regards
Markus
Thanks Markus,
I had a few of these ICs blowing up and just wanted to double check if the 44V limit was correct.
I have a voltage clipper circuit setup on the 24V supply but don't think this is working as should.
I will investigate further.
Thanks again,
Dan
Hello Luc123,
if you experience frequent failures maybe a closer look on power dissipation/output load for 24V supply might be a valid option.
Markus
Hello Luc123,
Markus
