AD628 simulation in LT spice doesn't work
ad628_sim.asc
I am trying to simulate AD628 in LT spice. I have attached the schematic here.
On Run, I cant get the output. I can see the input. Could anyone please help? I am new to spice simulations. My aim is to design an inverting amplifier and a non inverting amplifier with AD628.
regards
Rekha K
My ain is to get an inverting and non inverting amplifier with Ad628
[edited by: rekhak at 8:09 AM (GMT -5) on 18 Jan 2021]
    on Jan 19, 2021 5:46 PM 1 month ago
    I can also replicate your AD628 issue (no output in simulation). I've asked folks who are more familiar with the AD628 pspice model for help.
    I'll let you know when I hear back.
    Hooman
  • Thanks for the help Mr Hooman.
    regards
    Rekha K
    on Jan 22, 2021 9:54 PM 1 month ago in reply to rekhak
    Hi Rekha K,
    The folks in charge of AD628 model have sent me a new macromodel (with changes "commented") which seems to work in that the Output waveform does show up. I understand the input clamps are not functional in this model, but I've not tested that feature.
    LTspice does seem to run with the circuit you'd attached on Jan. 17 as shown below:
    Please take a look and see if this macromodel works for your purposes. You'd need to change the file extension from the current *.txt to *.cir instead first:
    AD628conv.txt
    * AD628 SPICE Macro-model
    * Description: Amplifier
    * Generic Desc: High CM Voltage Programmable Gain Diff Amp
    * Developed by: Scott Hunt
    * Revision History:
    * 1.0(12/2013) - SH
    * Refer to http://www.analog.com/Analog_Root/static/techSupport/designTools/spiceModels/license/spice_general.html for License Statement. Use of this model
    * indicates your acceptance of the terms and provisions in the License Statement.
    * BEGIN Notes:
    * Not Modeled:
    *   Temperature effects
    * Parameters modeled include:
    *   Vos
    *   Gain error
    *   Noise
    *   CMRR
    *   PSRR
    *   Output range
    *   Input range
    *   Supply current
    *   Slew rate
    *   Gain/phase
    *   Bandwidth
    *   Output current limit
    *   Output current reflected in supplies
    * Supply range:
    *    Single Supply: 4.5V to 36V
    *    Dual Supplies: +/-2.25V to +/-18V
    * Max CMV is the least of 120V or 11*(+VS - 1.2V) - 10*VREF
    * Min CMV is the greater of -120V or 11*(-VS + 1.2V) - 10*VREF
    * Typical Specifications used in Model
    * END Notes
    * Node Assignments
    *              Non-inverting input
    *               |   Negative supply
    *               |    |   Reference voltage input
    *               |    |    |     Filter Cap Connection
    *               |    |    |      |    Amplifier output
    *               |    |    |      |     |   Output amplifier inverting input
    *               |    |    |      |     |   |    Positive supply
    *               |    |    |      |     |   |    |    Inverting input
    .subckt AD628  +IN  -VS  VREF  CFILT  OUT  RG  +VS  -IN
    ****Gain = 0.1 Difference Amplifier Stage
    ***Resistors
    R62 -IN 2 RNoise 100e3
    R63 +IN 1 RNoise 100e3
    R65 2 4 RNoise 9.999e3
    R61 1 VREF RNoise 9.999e3
    ***A1 Differential Stage
    *********************************ORIGINAL LINES COMMENTED
    ;Q1 13 12 14 0 npn
    ;Q2 17 2 16 0 npn
    *********************************NEXT LINES ADDED (NOTE: This improves convergence but breaks VIH clamp based on bjt saturation)
    GQ1 13 14 12 14 19.33E-03
    GQ2 17 16 2 16 19.33E-03
    RC1 98 13 Rideal 3.6E+03
    RC2 98 17 Rideal 3.6E+03
    RE1 15 14 Rideal 3.548E+03
    RE2 16 15 Rideal 3.548E+03
    Dcmlim1 18 15 DQuiet
    Vcmlim1 18 51 1.226
    Ibias 15 51 1.00E-03
    Ios 1 2 0
    Vos 1 7 1E-04
    *******************************FOLLOWING LINES COMMENTED
    ;Cinv 2 0 1E-22
    ;Cninv 1 0 1E-22
    ***A1 Noise
    VVnoise 501 0 0
    RVNoise 501 0 RNoise 4E-05
    DVNoise 511 0 DVNoise
    VDNoise 511 501 0.1
    HVnoise 9 7 Vvnoise 1
    VInoise1 502 0 0
    RINoise1 502 0 RNoise 1656000
    DINoise1 502 0 DINoise1
    FINoise1 12 0 VINoise1 1
    VInoise2 503 0 0
    RINoise2 503 0 RNoise 1656000
    DINoise2 503 0 DINoise2
    FINoise2 2 0 VINoise2 1
    ***A1 Common Mode Rejection
    Rcm1 +IN 601 RIdeal 100E+06
    Rcm2 601 -IN RIdeal 100E+06
    Gcmr 0 602 601 0 1.00E-07
    Rcmr1 602 603 RIdeal 1E+07
    Rcmr2 603 604 RIdeal 31.62
    Lcmr 604 0 5.033E-03
    ***********************************ORIGINAL LINES COMMENTED
    ;Ecmr 10 9 603 0 1.0E+00
    **********************************NEXT LINES ADDED
    Gecmr 10 9 603 0 -1.0E+00
    Rgecmr 10 9 RIdeal 1
    ***A1 Power Supply Rejection
    ;Epsr1 700 0 98 0 1
    Gpsr1 700 0 98 0 -1
    Rgpsr1 700 0 RIdeal 1
    Rpsr1 700 701 RIdeal 1.00E+03
    Rpsr2 701 702 RIdeal 1E-03
    Lpsr1 702 0 7.958E-07
    ;Epsr2 11 10 701 0 1
    Gpsr2 11 10 701 0 -1
    Rgpsr2 11 10 RIdeal 1
    ;Epsr3 703 0 51 0 1
    Gpsr3 703 0 51 0 -1
    Rgpsr3 703 0 RIdeal 1
    Rpsr3 703 704 RIdeal 1.00E+03
    Rpsr4 704 705 RIdeal 1E-03
    Lpsr2 705 0 3.184e-04
    ;Epsr4 12 11 704 0 1
    Gpsr4 12 11 704 0 -1
    Rgpsr4 12 11 RIdeal 1
    ***A1 First Gain and Slew Rate
    GSlew 0 101 17 13 1.00E+00
    RSlew 101 0 RIdeal 2.5e+02
    DSlew1 101 102 Dzener
    DSlew2 0 102 Dzener
    *******************************NEXT LINE ADDED
    RSlew2 102 0 RIdeal 1E+06
    ***A1 Second Gain with Dominant Pole and Output Voltage Limiting
    ;*********************************ORIGINAL LINES
    ;Gp1 51 201 101 0 3.770E-08
    ;Rp1 201 51 RIdeal 1.061E+13
    ;Cp1 201 51 1.50e-12
    ;******************************NEXT LINES ADDED
    Gp1 51 201 101 0 3.770E-04
    Rp1 201 51 RIdeal 1.061E+9
    Cp1 201 51 1.50e-8
    Vlim1 97 206 1.55
    Dlim1 201 206 DQuiet
    Vlim2 207 52 1.45
    Dlim2 207 201 DQuiet
    ;Esupref1 97 98 51 0 1
    Gsupref1 97 98 51 0 -1
    Rgsupref1 97 98 RIdeal 1
    ;Esupref2 52 51 51 0 1
    Gsupref2 52 51 51 0 -1
    Rgsupref2 52 51 RIdeal 1
    ***A1 Additional Poles
    Gp2 0 202 201 51 1.00e-03
    Rp2 202 0 RIdeal 1.00e+03
    Cp2 202 0 5.30517e-11
    Gp3 0 203 202 0 1.00e-03
    Rp3 203 0 RIdeal 1.00e+03
    Cp3 203 0 3E-11
    Gp4 0 204 203 0 1.00e-03
    Rp4 204 0 RIdeal 1.00e+03
    Cp4 204 0 1.59155e-16
    Gp5 0 205 204 0 1.00e-03
    Rp5 205 0 RIdeal 1.00e+03
    Cp5 205 0 1.592e-16
    ***A1 Zeros
    Gz1 0 301 205 0 1.00e-03
    Rz1 301 302 RIdeal 1.00e+03
    Lz1 302 0 1.592E-10
    Gz2 0 303 301 0 1.00e-03
    Rz2 303 304 RIdeal 1.00e+03
    Lz2 304 0 1.592e-10
    Gz3 0 305 303 0 1.00e-03
    Rz3 305 306 RIdeal 1.00e+03
    Lz3 306 0 1.592e-10
    ***A1 Output with Current Limiting
    Gbuf 0 401 305 0 1.00e-04
    Rbuf 401 0 RIdeal 1.00e+04
    ;Eout 404 0 401 0 1.0E+00
    Gout 404 0 401 0 -1.0E+00
    Rgout 404 0 RIdeal 1
    Rout 405 404 RIdeal 2E-01
    ;Lout 406 405 1.0e-19
    ;Cout 406 0 1E-22
    Lout 406 405 1.0e-12
    Cout 406 0 1E-12
    Voutmon 406 4 0
    Dout1 401 407 DQuiet
    Vout1 407 406 -6.27E-01
    Dout2 408 401 DQuiet
    Vout2 406 408 -6.27E-01
    R6 4 CFILT RIdeal 10e3
    ***Reference Supply Generator
    ;Eref1 98 0 +VS 0 1
    Gref1 98 0 +VS 0 -1
    Rgref1 98 0 RIdeal 1
    ;Eref2 51 0 -VS 0 1
    Gref2 51 0 -VS 0 -1
    Rgref2 51 0 RIdeal 1
    ***Total Supply Current
    Iq +VS -VS .0016
    Fsup1 803 0 Voutmon 1
    Dsup1 +VS 802 DQuiet
    DZsup1 803 802 Dzener2
    Dsup2 804 -VS DQuiet
    DZsup2 804 803 Dzener2
    Fsup2 823 0 Voutmon1 1
    Dsup3 +VS 822 DQuiet
    DZsup3 823 822 Dzener2
    Dsup4 824 -VS DQuiet
    DZsup4 824 823 Dzener2
    *******************************FOLLOWING LINES ADDED
    RSup1 802 0 RIdeal 1E+08
    RSup2 803 0 RIdeal 1E+08
    RSup3 804 0 RIdeal 1E+08
    RSup4 822 0 RIdeal 1E+08
    RSup5 823 0 RIdeal 1E+08
    RSup6 824 0 RIdeal 1E+08
    ****A2 Op Amp (All unique nets are +20)
    ***A2 Differential Stage
    ;Q3 33 32 34 0 npn
    ;Q4 37 RG 36 0 npn
    GQ3 33 34 32 34 19.33E-03
    GQ4 37 36 RG 36 19.33E-03
    RC3 98 37 Rideal 3.6E+03
    RC4 98 33 Rideal 3.6E+03
    RE3 35 34 Rideal 3.548E+03
    RE4 36 35 Rideal 3.548E+03
    Dcmlim4 38 35 DQuiet
    Vcmlim4 38 51 1.226
    Ibias1 35 51 1.00E-03
    Ios1 CFILT RG 0
    Vos1 CFILT 27 1E-04
    *****************************NEXT LINES COMMENTED
    ;Cinv1 RG 0 1E-22
    ;Cninv1 CFILT 0 1E-22
    ***A2 Noise
    VVnoise1 521 0 0
    RVNoise1 521 0 2.2716E-04
    DVNoise1 521 0 DVNoise
    HVnoise1 29 27 Vvnoise1 1
    VInoise3 522 0 0
    RINoise3 522 0 1656000
    DINoise3 522 0 DINoise1
    FINoise3 32 0 VINoise3 1
    VInoise4 523 0 0
    RINoise4 523 0 1656000
    DINoise4 523 0 DINoise2
    FINoise4 RG 0 VINoise4 1
    ***A2 Common Mode Rejection
    Rcm3 CFILT 621 RIdeal 100E+06
    Rcm4 621 RG RIdeal 100E+06
    Gcmr1 0 622 621 0 1.00E-06
    Rcmr3 622 623 RIdeal 1E+06
    Rcmr4 623 624 RIdeal 31.62
    Lcmr1 624 0 5.033E-03
    ;Ecmr1 30 29 623 0 1.0E+00
    Gecmr1 30 29 623 0 -1.0E+00
    Rgecmr1 30 29 RIdeal 1
    ***A2 Power Supply Rejection
    ;Epsr5 31 30 701 0 0.1
    Gpsr5 31 30 701 0 -0.1
    Rgpsr5 31 30 RIdeal 1
    ;Epsr7 32 31 704 0 0.1
    Gpsr7 32 31 704 0 -0.1
    Rgpsr7 32 31 RIdeal 1
    ***A2 First Gain and Slew Rate
    GSlew1 0 121 37 33 1.00E+00
    RSlew1 121 0 RIdeal 2.5e+02
    DSlew3 121 122 Dzener
    DSlew4 0 122 Dzener
    **********************************NEXT LINE ADDED
    RSlew3 122 0 RIdeal 1E+06
    ***A2 Second Gain with Dominant Pole and Output Voltage Limiting
    ****************************** ORIGINAL LINES COMMENTED
    ;Gp6 51 221 121 0 3.770E-08
    ;Rp6 221 51 RIdeal 1.061E+13
    ;Cp6 221 51 1.50e-12
    Gp6 51 221 121 0 3.770E-04
    Rp6 221 51 RIdeal 1.061E+9
    Cp6 221 51 1.50e-8
    Vlim3 227 52 1.45
    Dlim3 227 221 DQuiet
    Vlim4 97 226 1.55
    Dlim4 221 226 DQuiet
    ***A2 Additional Poles
    Gp7 0 222 221 51 1.00e-03
    Rp7 222 0 RIdeal 1.00e+03
    Cp7 222 0 5.30517e-11
    Gp8 0 223 222 0 1.00e-03
    Rp8 223 0 RIdeal 1.00e+03
    Cp8 223 0 3E-11
    ***A2 Zeros
    Gz4 0 321 223 0 1.00e-03
    Rz4 321 322 RIdeal 1.00e+03
    Lz4 322 0 1.592E-10
    Gz5 0 323 321 0 1.00e-03
    Rz5 323 324 RIdeal 1.00e+03
    Lz5 324 0 1.592e-10
    Gz6 0 325 323 0 1.00e-03
    Rz6 325 326 RIdeal 1.00e+03
    Lz6 326 0 1.592e-10
    ***A2 Output with Current Limiting
    Gbuf1 0 421 325 0 1.00e-04
    Rbuf1 421 0 RIdeal 1.00e+04
    ;Eout1 424 0 421 0 1.0E+00
    Gout1 424 0 421 0 -1.0E+00
    Rgout1 424 0 RIdeal 1
    Rout1 425 424 RIdeal 2E-01
    ;Lout1 426 425 1.0e-19
    ;Cout1 426 0 1E-22
    Lout1 426 425 1.0e-12
    Cout1 426 0 1E-12
    Voutmon1 426 OUT 0
    Dout3 428 421 DQuiet
    Vout3 427 426 -6.27E-01
    Dout4 421 427 DQuiet
    Vout4 426 428 -6.27E-01
    *Models Used
    .model Rideal   Res(T_ABS=-273)
    .model Rnoise   Res(T_ABS=27)
    .model npn      npn(BF=499999)
    ********************************ORIGINAL LINE COMMENTED
    ;.model DQuiet   D(IS=1E-18)
    .model DQuiet   D(IS=1E-15)
    .model DZener   D(BV=11.337)
    .model DZener2  D(BV=50)
    .model DVNoise  D(IS=1E-15 KF=0.05)
    .model DINoise1 D(KF=0.0001)
    .model DINoise2 D(KF=0.0001)
    .ends AD628
    Hooman
