AD8324, problems
I'm building a board with a DSP. The DSP does a FFT on a analog signal. The signal is given a offset and we amplified with a ADA4853-1.
Then the Signal goes to the AD8324.
The AD8324 is set in single-ended. The Signal goes to the ADC on the DSP.
With an Logic Analyzer I have seen the SPI bus.
While Transmit:
Clk: 1 MHz
SData: 00011010
TXEN: High
Sleep (inverted): High
Data (inverted): Low
After Transmit:
Clk: 0 Hz
SData: Low
TXEN: Low
Data (inverted): High
And the AD8324 is still not amplifying. Picture : Channel 1: Input... Channel 2: Output
I don't know what's wrong!
