AD8138 Evaluation Board
What's the difference between AD8138AR-EBZ and AD8138AAR-EBZ?
Thanks.
Parents
  • Hi, Jay.Wang.
    The only difference between the two evaluation boards is the ADI part used wherein AD8138AR-EBZ utilizes AD8138 while AD8138AAR-EBZ utilizes AD8138A. The latter, AD8138A, is neither mentioned on the AD8138 product page nor on the AD8138 datasheet however, the table below shows the main differences between the two products and also the attached AD8138A datasheet may also be of help to you.
    Product specification
    AD8138
    AD8138A
    Dual supply
    Single supply
    Dual supply
    Single supply
    -3dB Small signal bandwidth (typ)
    320 MHz
    310MHz
    300 MHz
    Input offset voltage for VOCM to ±OUT (typ)
    ±1mV
    ±3mV
    ±4mV
    Quiescent current (typ)
    20mA
    20mA
    18mA
    PSRR (typ)
    -90dB
    -86dB
    -82dB
    Latest revision
    2006
    2008
    I hope this helps you.
    Anna
    AD8138Adatasheet.pdf
Reply
  • Hi, Jay.Wang.
    AD8138
    AD8138A
    Dual supply
    Single supply
    Dual supply
    Single supply
    320 MHz
    310MHz
    300 MHz
    ±1mV
    ±3mV
    ±4mV
    20mA
    20mA
    18mA
    PSRR (typ)
    -90dB
    -86dB
    -82dB
    Latest revision
    2006
    2008
    Anna
Children
No Data
