AD204 OSCILLATOR DRIVE INPUT
Hi,all
OSCILLATOR DRIVE INPUT SPECIFICATIONS @ AD204 datasheet,
Input Voltage 15 V p-p Nominal
Input Frequency 25 kHz Nominal
What is the margin tolerance for each spec.?
What is the ABSOLUTE MAXIMUM RATINGS ?
Best Regards,
sss
Parents
  • Hi sss,
    According to the product owner of this part, the AD204 was designed many years ago and the datasheets did not include Absolute Maximum ratings.
    He also added that knowing the AD204 module also generates internal voltages from the Oscillator Drive input, you should be safe operating with a +/-5% tolerance on the Oscillator Drive signal.
    The Oscillator Drive Input on the AD204 module was designed to be driven from our AD246 clock driver module which has enough drive current to power multiple AD204 modules.
    The frequency of the AD246 clock driver module is tested at the factory to be within 25KHz +/-10%.
    I hope this helps.
    Emman
Reply
  • Hi sss,
    I hope this helps.
    Emman
Children
No Data
