ADA4941-1 opened input signal
Hello
I am considering Sallen-Key, Low-Pass Filter like figure 54 on the datasheet.
There is a situation that the input is opened.
Then the output would be unstable.
Should I put termination resistor?
If yes, which value can I use?
There is a little oscillation at output because of load capacitance.
How can I compensate it?
on Mar 11, 2016 6:15 AM
power-man-san,
  What frequency?  What amplitude?
How much load capacitance?
I would suspect pc board layout first.
For a test, change the 1.69k resistor to 100 ohms.
Harry
  • I wanted to know the frequency and amplitude of the unwanted oscillation.
    WRT open input;, why not try a 10k pulldown on the input so there is something
    when the source is disconnected.
    Scope pictures?
    Picture of pc board?
    Harry
  • Hi Harry-san,
    When I removed the 2200pF, the oscillation is improved.
    Is it possible to inform me the load capacitance capability?
    Power-man
  • Power-man-san,
    There is no answer for "how much capacitance will this op amp drive".  Op amps have a finite
    output impedance.  So with a C, you have an R-C low pass which gives you phase shift and
    reduces the phase margin in your loop.  So it depends on what overshoot you can live with.
    10%??   30%???
    Unfortunately, the ADA4941 d.s. doesn't have overshoot vs. load capacitance graph.
    Fig 22 is not much help, but the fact that it has C>=0pF and 20pF tells me it can't drive much.
    Change the 33 ohms to 68-100 ohms and see if the frequency changes.
    Reduce the 1k/1k to 680/680 on the inverter stage.
    Drop the 7.5k feedback resistor to 100 ohms.  (don't worry about the offset)
    Harry
    Thank you,
    EZ Admin
