Hi All,
OP97 does not accept a single power supply? I tested it as I-V conversion function as attached.
Connecting 4 pin to -15V power, the OP97 output voltage changes corresponding to amount of light (OP97 works normally), but the output voltage does not change (2V fixed) when 4 pin is connected to GND.
If the OP97 accepts a single power supply, would you let me know what I should pay attention to design.
Kazu
