Hi !
I have some questions about ADI datasheet.
Our team are checking the datasheet because if the datasheet was changed we have to explain the changes.
And today , we found many datasheet was changed.
For just one example , AD8206 datasheet was changed.
I will attach the datasheet.
We found that P2 was changed
But the time stamp in the property was older than which I downloaded at past.
We always check the PDF property and the time stamp was older than the past datasheet so we are little bit confuse.
Also some parts changed the page number in spite of the datasheet Rev is not change.
Foe example AD8211.
When these thing happens , not only we are confuse.
Or customer will confuse too.
(We found same thing happens at these devices)
AD2S1205 AD605 AD8205 AD8206 AD8207 AD8210 AD8211 AD8417 AD8418A AD9057 ADA4571 ADCMP361 ADG719 ADM202 ADM3054 ADM7154 ADP1046 ADR512 ADuC7036 ADuC7039 ADuM3190 ADXL312 ADXL313
So my questions is ...
Q1)
Which timing would ADI change these kinds of pages?
Q2)
Also when you change these pages , why don't you change the revision?
We want to know this because we are checking and make the backup database for the datasheets regularly and it is very tough work when we found the updates.
Best regards.
Kawa
Hello Kawa-san,
The quick links page in the product datasheet provides you with links to relevant information pertaining to the device, such as application notes, spice models, reference circuits, etc. It is dynamically generated to provide the customer with the most recent content on the web that is related to the device, and so, may change when new content is available. This information does not have anything to do with device performance though, and is just generated to provide customers with an easy way to access content. As such, any change on this page does not require a revision change. Kindly see the footnote on the said page for more information.
I hope this helps!
Kris
Hi Kris-san
Thank you for your support everyday!
I understood.
Hello Kawa,
Thank-you for the EZ contact. I don't support this particular product but I can put you in contact with the apps engineer who does. Please use the following email contact information for information about the AD8206:
Paul.Blanchard@analog.com
Best of luck,
js
