connecting ad831 in parallel
 Hello every one,
I am software guy. Some how trying to use ad831 as a mixer connecting in parallel as seen on attached  file. +5V and -5V  are supplied to both of the mixers from the same source. The problem I faced is here. While measuring the supplied -5V  at each mixer it shows ~ -1.2V. what could be the problem?
    on Oct 15, 2019 12:41 PM
    Did you ground all three chips to same GND? What's the voltage you measured at the power supply? What is the current compliance for the power supply?
    Thanks.
  • Hello dear.
    Thank you  a lot for your help.
    Yes, I did. All of them are grounded to the same GND. I don't get the second question fully. If you meant  the output of -5V voltage regulator(MC78058), it is -1.2V as I said.
    A DC voltage  setting from the main source is +12V which connected  to Cosel MGFW152415 votage regulator. -15V output of MGFW152415 goes to  the regulator MC78058 which resulted in -5V.
    A current reading from the main source is 0.86A.
    By the way, while disconnecting  the mixers and measure  voltage supplied to each of them in dividually, -5v is perfectly dilvered.
    Thank you  a lot once again .
